how do you think for this spec? but i'm not sure about this build
my budget is around of this spec.. i cant afford higher budget than this spec
) (i will not overclocking)
i need a computer that is good for design graphic (not video editing or 3D) and good for gaming also (dota 2 & PES)..
have any better suggestion for this spec?
intel LGA 1155
intel i5 3570 (Box) 3.4Ghz,Cache 6MB intel LGA 1155
MB. Intel 1155
ASRock H77 Pro4/MVP intel Socket 1155
Memory DDR3
G.SKILL F3-1600C9D-8GAB Performance Series - Ares PC3-12800 / DDR3 1600 MHZ (2X4GB)Timings 9-9-9 1.5V DDR3 Performance Series - Ares DDR3
Harddisk 3.5Inch
Seagate SATA III 1TB 7200RPM 16Mb 3.5Inch Int 3,5 Inch
Ati PCI Exp.
Digital Alliance HD 7770 1Gb 128Bit DDR5 Ati Radeon PCI Exp
PSU Under 600w
Cooler Master Extreme Power Plus 500W Regular
LCD Under 19"
LG 19 Inch 19EN33V HDMI Size 19 inch
Casing Mid.Tower
Venomrx Temujin Black No PSU
) (i will not overclocking)i need a computer that is good for design graphic (not video editing or 3D) and good for gaming also (dota 2 & PES)..
intel LGA 1155
MB. Intel 1155
Memory DDR3
Harddisk 3.5Inch
Ati PCI Exp.
PSU Under 600w
LCD Under 19"
Casing Mid.Tower
