Hi,
I was wondering if anyone could help me figure out what I should upgrade first in my computer. My computer is used primarily for gaming (WoW, SWtoR, D3, SC2, and various Steam games), and while none of these games are particularly taxing, my current rig cannot quite run them at ultra (with the exception of SWtoR and some Steam games). I'm just not sure where I will get the biggest upgrade. Here is my current computer's specs:
Operating System: Windows 7 Ultimate
Boot/Game Drive: Adata 128gb SSD (6gb/s)
Storage Drive: 2tb Seagate Barracuda (7200 RPM, 6gb/s)
MoBo: ASRock Z75 Pro3
RAM: GSkill Ripjaw X 8gb (1600)
CPU: i5 2500k (OC'ed to 4.5ghz)
CPU Cooler: Cooler Master Hyper 212 Evo
GPU: MSI Twin Froze II 7950 (@ 1075/1575 on stock volts, can push it to 1200/1600 stable with voltage boost and 70-80* temps)
PSU: OXZ ModX Stream 620w PSU
Case: NZXT Phantom Crafted Series
So, again, my question is which component to upgrade first to give me the largest upgrade? When I first built this computer, it was on a budget so I could slowly upgrade later (have added windows ultimate and the 2tb drive), and now I'm looking to buy some of the better parts available to upgrade. Thanks for any help, it is appreciated.
Edit: Added PSU to list, thanks for pointing that out.
. It's a bit of a hassle, but just back up your hard drive and reinstall the OS, using your current product key. If your product key is OEM, then technically you'll have to buy a new OS key, since it's tied to the hardware. You may be able to get Microsoft to renew your OEM key if you tell them you replaced your MOBO due to hardware failure.
