I am planning to upgrade my pc and wanted suggestions for choosing some parts. I primarily use my pc for fps gaming (Pubg, Apex, etc.) I plan to start streaming after i upgrade my pc.
My current setup:
CPU: G4560
GPU: 1050ti
Mobo: Intel B250 - GA-B250M-DS3H
RAM: HyperX 8GB 2400MHZ DDR4 HX424C15FB2/8
Monitor: some cheap Aoc 60hz tn panel
Updated build:
CPU: i7 7700
GPU: Rtx 2060
RAM: Same stick for 16gb ram
Monitor: Not sure, need help!
Would an i7 7700 ($360) be good enough or should i get i5 9400f ($173) i know i'll have to buy new mobo (hoping i'll find a decent one at ~$144-173), will my current ram stick support new cpu/mobo or will i have to buy new ram? (In this case, things will get too expensive for me).
As for a monitor, i've done some research but due to my lack of knowledge unable to settle for one. Don't want to settle for a cheap one but can't afford the high end option. The main things i am looking for is 1080p 144hz 1ms i am fine with tn panels as my primary use is gaming. I've shortlisted a few monitors please help me decide one.
Will enquire about first 2 monitors in local stores. I am leaning towards KG271 as it's the cheapest option on the list, but couldn't find any reviews about it so a little skeptical. Anybody has any experience with it?
Additional info:
Country: India
Budget: $1150
Any help will be appreciated, thanks in advance!
My current setup:
CPU: G4560
GPU: 1050ti
Updated build:
CPU: i7 7700
GPU: Rtx 2060
Would an i7 7700 (
- Viewsonic XG240R - NA (price na online)
- Acer VG271 - NA (price na online)
- Acer KG271 Cbmidpx - ~$288 (no reviews)
- BenQ XL2411P - ~$288 (Safest option, i guess)
Additional info:
Country: India
Budget: $1150
