[SOLVED] Need help from PSU Gods, (SeaSonic) PRIME vs PX. ??
EvooHD
309
7
18,865
Hello, i would like an advice from any that has knowledge about PSU Brands or tiers, i know stuff but, at this moment i just out of my range, from power i think 750W is plenty.
My new gpu will arrive in few days (RTX 3070 Ti Gaming oc) and i was thinking if my PSU will be enough not only power wise but overall stability.
Right now im using " SeaSonic PRIME Platinum 750W" Platinum
View: https://imgur.com/oqAH3sc
(IMAGE of PSU what im talking that im using now for 1 year)
and the new series "SeaSonic PRIME PX Series 750W" Platinum
There is also the "SeaSonic PRIME TX Series 750W" Titanium
my Q is ,whats the difference between PX and Standart PRIME Platinum??? Did they change their name to PX? or im missing something, i have found 0 info about this.
Thanks.
Juular
Respectable
BANNED
Mar 14, 2020
1,061
259
1,940
If it works then it works. If it doesn't then you need to get a different 750W PSU, not Seasonic Prime.
The only difference is the name. PX is a rebrand of Prime Ultra Platinum.
Reactions: EvooHD
