Hi, so This is my own built computer that I completed in Jan 2017. My problem all started out of the blue while gaming , my monitor crashed and it said no signal and the GPU fans went up to full speed, I had to restart my computer in order to fix that, after that the crash would occur randomly until I could not even have the computer on for more than 5 mins without it crashing. So after reading alot of similar issue online I decided to RMA my card and buy a brand new one to skip the waiting. Got my new card yesterday, installed it and powered my computer to find out it did the same thing happening, MOBO splash bios loads and then no signal and gpu fans spins full speed, tried re-setting the computing several times and i would never make it to the windows login screen. The computer works fine if I plug the display into the MOBO and use integrated graphics. Via MSI afterburner the graphic card temp never went above 70c when crashing , CPU was around 60C
Here is what I did software wise:
Here is what I did hardware wise:
Here is my system info:
CPU: Intel core I5 6600K
MOBO: MSI Z170 Krait gaming
GPU(old): MSI Gaming 6G Geforce 1060 , 6gb VRAM
GPU(new): MSI Titanium Geforce 1070TI.
PSU: EVGA NEX650G 650watt gold80
OS: windows 10 home edition
RAM: 2X 8GB DDR4 G.skill Ripjaw 3400Mhz
Cooling: CPU is watercooled Corsair HI60, the rest of the case is fan cooling with a total of 2 fans
At this point I am going to try the PSU I am scared I might of damaged my new card by installing it into this rig.... Any help would be appreciated.
- updated the MOBO BIOS
- updated the graphic cards drivers ( initial one)
- Clean windows 10 install
- checked ALL PSU cable and plugged them in properly
- Re-seated gpu card and changed PCI slot both unsuccessfull
