Hello guys. So, I want a gaming computer for christmas and my budget is low, so since it is my first and I don't understand nothing about hardware I came here to get your help. I've been reading other posts but none of them really met my requirements, so I've created an account and started my own.
Approximate Purchase Date: Christmas
Budget Range: 700-800€
System Usage from Most to Least Important: gaming, surfing the net, general uses.
Are you buying a monitor: Yes
Do you need to buy OS: No
Parts Preferences: I don't have any preferences. I want the better parts, no matter the brand.
Overclocking: GPU Maybe / CPU No
SLI or Crossfire: Maybe in the future but probably not.
Your Monitor Resolution: I don't have a monitor yet, but I think 1080p is the way to go.
Additional Comments: Need a gaming pc, future-proof, no recording nor rendering.
And Most Importantly, Why Are You Upgrading: Since I started gaming, the only computers I had were laptops and I always had to lower the resolution and the settings to the minimum (and some of them still didn't run at decent fps). So now, I just want a computer to play all the games, and the ones that will come, without having that fps lag which is very annoying. With this budget I would want the best performance for gaming. I know it won't last forever but I will only upgrade when the future games can't be run with the lowest settings (I have no problem playing at low settings, I've got used to it), and I hope that day will take long to arrive.
So, short story short, I want to play all the recent and future games at decent fps for the maximum of time.
Now, the shop is limited, I know, but I can only buy from here (I will post the links from the parts, since the shop is in portuguese):
Processors
Motherboards
RAM
Graphics Cards
Hard Drives(not more than 500GB since in my current pc Im only using 100GB)
Cases(maybe the cheapest one)
Power Supplies
Cooling(don't think I need it since Im not overclocking the CPU but Im a hardware noob so, feel free to give your opinion)
DVD Burners(maybe the cheapest one)
Monitors(I know nothing about monitors but maybe 1080p)
Thanks guys.
Processors
Motherboards
RAM
Graphics Cards
Power Supplies
Thanks guys.
