Need help identifying graphics card
foshizz
164
Ok so my graphics card is clearly labeled nvidia.
It looks remarkably similar to the quadro fx 3400, but has no stereo port.
Here's a couple of markings:
•8974 ver 120
•rev a02
•cn-or7240-69702-4b4-0949
And under the tiny nvidia logo is:
•180-10211-0000-a03
Note that there is no nvidia fx sticker anywhere,as the pictures I see in google.
nbelote
953
What's a stereo connector? Could you mean dual monitors, as in you are referring to the second DVI port? Or are you referring to the S-Video port? Not having one or both of those and having one DVI out does not mean it has to be a different card.
Oh, and try GPU-Z like everyone has been saying. Its the only REAL way to know for sure.
foshizz
164
I can't use gpuz since mobo is dead. The stereo connector is the little circly thing evolve the two dvi ports. Yea my explanation is bad, I know.
I think it's what does 3-d.
It's not a "stereo" connector, and it's not for 3-D.
I think you mean ABOVE the dvi ports not evolve. It's probably a S-video out, could also be used for a break-out box for more connections, but it's probably S-Video. I have seen cards with a wireless connector for 3D glasses that use a connection to the video card, but the only ones I have seen like that was on a SGI workstation.
