Hello, I am new to this forum but it seems like it has a great community. Each networking scenario is unique and I was hoping to get some ideas and inspiration from this vibrant community.
I am not a network engineer by any specs, but I have put in my hours and got my scars enough to tackle this issue. I will attach a current network diagram for you to view and get some insight into the situation and list the requirements as followed.
We are looking to reduce the amount of hardware and improve security, while still being able to block websites by category and static IP or user. This network has been added on to several times as the company has expanded and everything about this setup is really incorrect. Since I am on a tight budget, I need to replace as little as possible. The network needs user specific website blocking. Right now they are using the netgear as it has a included openDNS membership. The netgear router is also the point of failure and it goes down nearly every two days, but if it goes I need to replace the website blocking mechanism. Controlling the network web filtering is important. I was thinking a UTM or NGFW would be good, So right now I was thinking of either replacing the netgear with one of these options
- Mikrotik CRS125-24G-1S-2HnD-IN (24 ports to maybe get rid of some of the lower switches, lacks a good content filtering solution)
- Mikrotik Routerboard RB2011UiAS-2HnD-IN (10 port, same as above but less ports, less power overall)
- ZyXEL ZyWALL USG20W 802.11n Wireless Internet Security Firewall with 4 Gigabit LAN/DMZ Ports, 2 IPSec VPN, SSL VPN , and 3G WAN Support ( Has cloud firewall, website filtering, and more. It seems to be recommended for a 5 user network, which seems very underpowered for the traffic we will pass through)
I have been searching for solutions to replace the netgears web filtering at a reasonable price for the budget im in. OpenDNS Umbrella will want like 25 a user, which is outrageous for DNS filtering. Cloud solutions look good on the $200-$300 UTM / NGFW solutions but they all seem to be light throughout unless u go into $600+ range. Client doesnt mind paying 100-200 a year for web filtering but we don't have active domain configured. Its def an option though.
Those were the options I found before I found out we dont need wireless anymore. Now I know I can use a swtch, but I need some suggestions and help. Its really important we can filter the internet by static IP as well.
NETWORK DIAGRAM
NETWORK DIAGRAM
