need help in building a gaming pc
idontknow281
Commendable
Jun 21, 2016
7
i have $4900 to build a gaming pc and i would like a green and black theme. this pc will only be for gaming. would play games such as csgo, battlefield 4, star-wars battlefront, and the witcher 3. I also need these games to run at 60 fps on 4k ultra
I do not need a monitor or peripherals. I would prefer windows 7. and would run games such as fallout 4, csgo, doom, and the witcher 3, and no i do not need to overclock. I also live in the US
No overclocking, but SLI GTX 1080 GPUs more than ready for 4k gaming on multiple monitors. Kept a green / black theme with green LEDs (custom part)...
CPU: Intel Xeon E5-1650 V3 3.5GHz 6-Core Processor ($564.99 @ SuperBiiz)
CPU Cooler: Noctua NH-L12 37.8 CFM CPU Cooler ($59.58 @ OutletPC)
Motherboard: Gigabyte GA-X99-UD3P (rev. 1.0) ATX LGA2011-3 Motherboard ($155.91 @ Newegg)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2666 Memory ($64.99 @ Newegg)
Storage: Sandisk X400 512GB M.2-2280 Solid State Drive ($124.99 @ Amazon)
Storage: Western Digital Caviar Green 3TB 3.5" 5400RPM Internal Hard Drive ($96.49 @ OutletPC)
Video Card: EVGA GeForce GTX 1080 8GB Founders Edition Video Card (2-Way SLI) ($699.99 @ SuperBiiz)
Case: Raidmax Viper GX ATX Mid Tower Case ($70.98 @ Newegg)
Power Supply: EVGA SuperNOVA P2 850W 80+ Platinum Certified Fully-Modular ATX Power Supply ($114.99 @ NCIX US)
Optical Drive: LG WH16NS40 Blu-Ray/DVD/CD Writer ($50.98 @ Newegg)
Operating System: Microsoft Windows 10 Home OEM 64-bit ($83.89 @ OutletPC)
Other: BitFenix BFA-ACL-12GK6-RP Alchemy Connect LED-Strip Green 12cm ($13.99)
Total: $2801.76
If you don't want to overclock you'll come in way under budget. Not sure why you wouldn't want windows 10 but that's not really my choice.
i7-6700 Build
Only issue is the black and green color scheme. Nothing really uses black and green that much that I can find, so short of putting in some LED strips and painting stuff you're kind of stuck. It will perform incredibly well though
CPU: Intel Core i7-6950X 3.0GHz 10-Core Processor ($1649.99 @ NCIX US)
CPU Cooler: NZXT Kraken X31 69.5 CFM Liquid CPU Cooler ($68.89 @ OutletPC)
Motherboard: Gigabyte GA-X99-GAMING 5 ATX LGA2011-3 Motherboard ($298.95 @ Micro Center)
Memory: Corsair Vengeance LPX 64GB (4 x 16GB) DDR4-2400 Memory ($239.99 @ Newegg)
Storage: Sandisk X400 1TB M.2-2280 Solid State Drive ($259.99 @ Amazon)
Storage: Western Digital BLACK SERIES 2TB 3.5" 7200RPM Internal Hard Drive ($117.88 @ OutletPC)
Total: $4370.50
So long as you realize you won't see any performance boost going over either this or sadam's builds pretty much just go onto PCPartPicker and start picking random expensive stuff. There literally won't be any real advantages to choosing anything over what we've suggested.
Here's another option for a sub $3000 Build
i7-6800k Build
