Need help in choosing a GPU
praveenastra
4
My System specs are below
Intel i5 Processor (4M Cache, 3.20 GHz)
4GB DDR3
400W PSU
Monitor - 1600x900
Am planning to upgrade my old GPU(HD 4350), currently am checking between HD 7750 & HD 7770
With my old PSU i think i may be able to use 7750
But if i need to go for 7770 then i need to change my PSU
Should i go for 7770 even if it costs me more(also need to change PSU)?
I don't play much in online, but try out the latest games(AC series, Crysis, COD etc) mostly RPG, so is the card 7750 enough for me.
help me out plz
Where the heck did you get a GTX 580 from?? OP asked for choice between 7750 or 7770...
I would also agree with Darth, if it's a good quality 400W PSU, the 7770 will be fine. If it's a cheap, generic brand 400W PSU, go with the 7750 (with GDDR5 memory) or perhaps you should even consider getting a good quality PSU and upgrading your graphics card at a later stage (although, I admit, I wouldn't be too keen on doing that either).
You should be permanently banned from this website for using hwcompare. Only people who know nothing about graphics cards uses it. Also, where the hell did you get a 580 from?
