Need help in choosing a laptop for my dad's employee
Aug 4, 2022
18
So,My dad wants to give a laptop for my employee to work with. We came across three choices of laptop. I'll give you guys the specs of those laptops below. One of the laptops are out of budget but our dad needs a good laptop.
The work the employee does is Excel,AutoCad and presenting some thing in meetings etc. I said an i3 will be fine but dad wants to be sure,so i came to ask you guys. Any help?
Here is the specs of the three laptops:
laptop 1:
Dell Inspiron 5510 (i5/Blue)
– Intel Core i5-11320H 11th Gen Processor
– 8GB DDR4 Ram
– 512GB NVMe SSD
– Intel IrisXe Graphics
– 15.6″ FHD (1920 x 1080)
– Office Home and Student 2019
– Blue Color
laptop2:
Asus X515EP i5 11th GEN with fingerprint reader
Intel® Core™ i5-1135G7 Processor (8M Cache, up to 4.20)
8GB DDR4 3200MHZ
512GB NVME M.2 SSD
15.6" 1920x1080 Anti-Glare NTSC: 45%
NVIDIA GeForce MX330, with 2GB GDDR5 VRAM
1.7kg, 37WHrs
FREE ASUS BACKPACK
FREE WIRED OPTICAL MOUSE
2 Years warranty
Genuine Windows 10 Home 64Bit Pre-installed
Finger Print Reader
Laptop 3:
Asus X515EA i3 11th GEN with fingerprint reader
Intel® Core™ i3-1115G4 Processor 3.0 GHz (6M Cache, up to 4.1 GHz)
4GB DDR4 3200MHZ
512GB NVME SSD
Intel® UHD Graphics
1.7kg, 37WHrs
FREE ASUS BACKPACK
2 Years warranty
Finger Print Reader
Aug 3, 2022
44
+1
- plus no1 is unsuitable IMO also
an i3 shouldn't be considered - a decent I5 absolute minimum
and remember that newer u chips are often significantly less powerful than some older m/mq chips
No2 with 16GB (32GB preferred) seems a minimum to me for cad apps for anything other than basic stuff
  • and even then a 15.6 screen is rather small
  • expect to need and budget a 21"+ external hi-res monitor for real work and for even that laptop to struggle if some reasonably complex cad work is done
18
the emplyee does very minimum autocad like 1/100 so it is fine ig. plus like the plans they do in that is very simple and just 2d. will the i3 laptop be enough???
Aug 4, 2022
18
our dad tells me to get the i5 for him but I said i3 will be fine but i never thought of the ram,does the ram needs to be increased??
Aug 3, 2022
44
Try it yourself on whatever machine you are using ...
even just a couple of moderate sized spreadsheets on a 15.6 screen
.. although your 'cad' requirements seem pretty basic although consider any growth in requirements
Consider
Do you really want an employee sitting around with a windows circle of death while you are paying him?
Listen to your dad and stop trying to save a few $$ that will cost you 100's or 1000's in the longer run
You have two opinions that the i3 isn't up to it
and you really do need at least a basic dedicated GPU, shared memory cpu/gpu is a double hit.
Reactions: prolong
