Need help in finding 3 components for gaming. budget of $350 (Sing dollars)
Immunity50
Hi guys, I need your help in finding a:
1) Mechanical Keyboard
2) Graphics Card
3) 120 Hz monitor
all these items should have a combined price of $350-400 max. i wouldn't mind the graphics card/monitor to be of an older model, as long as i can run First Person Shooter (FPS) games like BF3,COD,TF2.etc on medium to medium low resolution. All i require is for the graphics to be at least a little bit aesthetically pleasing, but my main priority is for the frame rate to be smooth.
i am currently running on a rather tight budget, so i would appreciate it if you guys could suggest some value deals with the links. Thanks!
Mechanical keyboard: http://www.google.ca/imgres?imgurl=http://3.bp.blogspot.com/-8AxotqFxchQ/T7RmLwoV0bI/AAAAAAAABuk/OzWu8zgnlQM/s1600/typewriter.gif&imgrefurl=http://faithincommunity.blogspot.com/2012/05/pity-poor-typewriter.html&h=481&w=700&sz=31&tbnid=jqNUNUIPR0Xe3M:&tbnh=90&tbnw=131&prev=/search%3Fq%3D%2522typewriter%2522%26tbm%3Disch%26tbo%3Du&zoom=1&q=%22typewriter%22&usg=__i6tho1mUKbuw3_gy7M1-UN85ODg=&docid=Kq6dMRxqcDjazM&sa=X&ei=w0jCUNuiK4rOqQHMmIDQBw&ved=0CEMQ9QEwBA&dur=5
Usually even walmart but I suggest fry's electronics or bestbuy, you can get Micro Innovations, Inland or even a Logitec KB for $10.
Graphics card depends on the motherboard in your system, are you running a "mechanical" AGP or do you have PCI-E slots ?
I suggest AMD because they beat nVidia in any 3D game comparison on framerates and AA. http://www.newegg.com/Product/Product.aspx?Item=N82E16814131481 at $90.00 not too bad.
The newest LED might have a model with a vertical refresh of 120hz but it will NOT be in your budget, http://www.newegg.com/Product/Product.aspx?Item=N82E16824260068. Try this one instead at $180 http://www.newegg.com/Product/Product.aspx?Item=N82E16824009245.
Why did you link him a typerwritter article for a keybd? LOL
Sorry I dont know any singapore places to check pricing or availability.
This is about the cheapest decent mechanical keybd I know of.
http://www.amazon.com/Azio-Levetron-Mechanical-Keyboard-KB528U/dp/B008CXTW42
And AMD 7850 2gb is about $170 here with the 7870 being around 240 if you can afford it.
120hz lcd panel? Probably not going to happen in your budget.
