Need help in hardware question
Vindr
6
So I have been having some computer problems from time to time when it comes to gaming and I believe I have narrowed down the possibility of it being a power supply problem. The thing is though I dont know much about hardware and I want someone to double check what I have put into this site: http://outervision.com/power-supply-calculator. heres the details and let me know if you come to the same conclusion of what I should do.
Motherboard: desktop
CPU: amd socket AM3+ AMD FX-4300 380 MHz VISHERA
memory: 2 4gb ddr3 module
Video card: Nvidia geforce GTX 750 ti
storage: SATA 7200 RPM
Optical Drivers: DVD-RW/DVD+RW Drive
Current power supply:atx-xg500w 12v
heres a link to where i purchased my computer (minus the change to the video card addition) http://www.amazon.com/CyberpowerPC-Gamer-Ultra-GUA880-Desktop/dp/B0089KDCIU/ref=sr_1_3?m=ATVPDKIKX0DER&s=pc&ie=UTF8&qid=1416950963&sr=1-3
Thank you in advance for your help.
What kind of problems are you having?
The 750ti uses no power, unless you're overclocking your 4300. A 300-350w PSU will do.
Of course, they didn't specify the make of the PSU. Probably a terrible one, so failure is likely. With any premade systems, they usually cheap on the the PSU and the mobo.
In short, for some reason unknown when playing a game well within my abilities to, say the MOBA smite, the screen will just go dark out of no where. At first I thought it was the video card, but i ruled it out because it is only a year old. After that I looked at my heat sink on my CPU. Figured it was going bad so i got it switched out just today and had the same problem. So I am down to it being either the power supply or the video card. Thoughts?
you can run stability tests to check each component.
do you have any personal recommendations on what I should use? going to search now in the mean time
thank you for your help. ill do the stress test and see what comes up.
Update: so i did all the tests and nothing seems to be wrong, but i dont know if I tested the power supply. beyond that could it be the air flow in the case itself?
