D dontcare77777 Prominent Dec 29, 2018 6 0 510 Jun 20, 2020 #1 Allright, so I having Win 7 32bit, want to patch with PAE patch it for using more than 4 GB of RAM, and have like this : How to resolve this issue ?
Solution Math Geek Jun 21, 2020 can't do it. if you want to try some random thing no one has even heard of, then you'll need to go back where you got it and ask them. cause it is not possible. you need 64 bit windows which takes a fresh install
rgd1101 Don't Moderator Nov 7, 2011 74,247 4,081 176,290 Jun 20, 2020 #2 do a fresh 64bit install Upvote 0 Downvote
D dontcare77777 Prominent Dec 29, 2018 6 0 510 Jun 21, 2020 #3 Don't want to. Need to patch the current one. Last edited: Jun 21, 2020 Upvote 0 Downvote
Math Geek Titan Ambassador Oct 15, 2014 18,485 2,561 104,090 Jun 21, 2020 Solution #4 can't do it. if you want to try some random thing no one has even heard of, then you'll need to go back where you got it and ask them. cause it is not possible. you need 64 bit windows which takes a fresh install Upvote 0 Downvote Solution
D Deleted member 14196 Guest Jun 21, 2020 #5 dontcare77777 said: Don't want to. Need to patch the current one. Click to expand... Too bad because that’s your only way out Upvote 0 Downvote
D dontcare77777 Prominent Dec 29, 2018 6 0 510 Jun 21, 2020 #6 Math Geek said: if you want to try some random thing no one has even heard of Click to expand... PaE patch Upvote 0 Downvote
USAFRet Titan Moderator Mar 16, 2013 176,272 20,311 184,590 Jun 21, 2020 #7 OK... You've found the code and procedures to implement the PAE extension. Why haven't you tried it yet? Upvote 0 Downvote
D dontcare77777 Prominent Dec 29, 2018 6 0 510 Jun 21, 2020 #8 I patched allready. Dont know how to disable the driver verification for it. Last edited: Jun 21, 2020 Upvote 0 Downvote
