Need help in PC (Read description for further information)
Melonator
77
Recently i opened my pc and i saw this, "Rescanning files (and) Fixing files"
Afte that my pc is now on the desktop with all the icons, shortcuts etc. i though everything was fine until:
-It starts up (very) slowly
-Cant open all the files (except windows explorer) like: Important documents, powerpoint, word, one note etc., google, steam, videos, music and more
- Responds (very) slowly
- It wont' open the windows button (im at windows 10)
SYED MUBARAK MEHDI
Commendable
Jan 14, 2017
41
8
Hi Melon, -- I believe your PC system files might got infected by virus, scan for virus. and also execute below steps.
Close any open programs on your Desktop
Click on the Start button
Click Run
Type this command in the Run box: SFC /SCANNOW
Click the "OK" button
Melonator
77
Hello, i cant open run since the startup button wont work
Colif
does ctrl alt del bring up a blue menu with task manager as a choice?
open task manager
choose file, run new task
type cmd and before hitting OK, select Create the task with admin privileges
then try sfc /scannow and press enter
his instructions won't work as the Run he sent you too doesn't have admin access.
Melonator
77
At first i tried the ctrl alt delete, i picked task manager. But it didnt open, so i waited for a few minutes and try again, now ctrl alt delete wont work as well
Colif
hmmm....
when you login, do you normally have to put password in or does it log you direct to desktop?
If you have to put password in, don't. Instead, look at the 3 icons in bottom right of screen, one is power
open the power menu so it shows sleep, shutdown and restart
while holding down the shift key, click restart
PC should restart and load advanced start up
choose troubleshoot
choose advanced
choose start up options
click the restart button on screen
choose a safe mode (it doesn't matter which) by using number associated with it.
PC will restart and load safe mode
is PC slow here? if its normal then the problem might be a driver on your PC. right click start button and choose device manager and see if any unknown devices or warnings
sometimes just booting into safe mode and exiting again can fix errors
another choice is restart PC again, come back into advanced startup like I showed above and run start up repair
choose troubleshoot
choose advanced
choose start up repair - this will scan PC and maybe fix this - will ask for logon info
If your PC auto logs into desktop, getting to this menu relies on ctrl alt del again and choosing log out as it will bring you to the login screen mentioned above. You may need to restart PC to get ctrl alt del working again.
is there anything on C drive you want to rescue? try making this on another PC: http://www.howtogeek.com/howto/windows-vista/use-ubuntu-live-cd-to-backup-files-from-your-dead-windows-computer/ << as this will let you copy files without windows acting dumb and stopping you. You might be best doing a fresh install so back up everything you don't want to lose.
Also, on another PC, download the Windows 10 media creation tool and use it to make a win 10 installer on USB
change boot order in BIOS so USB is first, hdd second
boot from installer
follow this guide: http://www.tenforums.com/tutorials/1950-windows-10-clean-install.html
when you reach screen asking for licence, click "I don't have a key" and win 10 will continue to install and reactivate once finished
On the screen where you choose where to install win 10, if it gives you an error about GPT drives, delete all the partitions on the hdd and press next. If it still gives error, cancel out of the installer and restart PC and start installer again, it will accept next on that screen this time (some PC just need a restart here)
Melonator
77
Thanks, ill try all of these steps and update you after this
Melonator
77
So i did these steps ans here is what happened
1. Safety mode still goves the same results
2. Startup repair wont work as well it says
"Startup repair couldnt repair your pc . log file D:\WINDOWS\System32\Logfiles\Srt\SrtTrail.exe"
If i choose reset this pc and keep my files
Will all my important files will be there like documents, videos etc?
Because it says removes apps and settings but keeps your personal files
Colif
it should keep everything in documents, music, pictures, videos - the library folders. If you can, copy them onto USB just in case it doesn't work and you need to fresh install. It sounds like your windows is really sick so the reset may not work either. Try it though.
SYED MUBARAK MEHDI
Commendable
Jan 14, 2017
41
8
You can do this through command prompt also.
click on start and type command
next right click on command as select run as administrator
now here you can execute the same command.
SYED MUBARAK MEHDI
Commendable
Jan 14, 2017
41
8
Melonator
77
Already tried that, srttrail.exe blocks it
But yeah my pc has recovered already
