need help in RAM
nero0220
8
I using Gigabyte P55-UD3L rev2.3 motherboard
i currently have three ram
Kingmax 2gb 1333mhz
Kingmax 2gb 1333mhz
Kingston 4gb 1333mhz
how should i place the ram in the motherboard slots? There are two white and two blue slots
http://s21.postimg.org/6fw4tdmir/IMG_3519.jpg
http://s21.postimg.org/cjdpdacsj/IMG_3520.jpg
http://s21.postimg.org/dkdy2ets3/IMG_3521.jpg
http://s21.postimg.org/e7curxqo3/IMG_3522.jpg
because if i simply place it, it can't startup and get a continuously beep sound
or i will get 8gb (3.99 gb usable) or 8gb (5.99 gb usable)
thanks
Try each stick individually (the 2 GB ones) to see if they will work with the mobo. If they do try the 4GB in slot 1 closest to CPU, go into BIOS and raise DRAM voltage + 0.06, save, exit, shutdown . Then try adding the 2GB sticks in slot 3-4. (might also ensure you have latest BIOS)
