Need help in selecting GPU and cooling fan for my pc
ashton10
54
I have bought a new pc and i noted that its cabin size is too small. So i need help in selecting a good gpu for this pc and a cooling fan to keep the temperature low
this is my pc
HP 260-p022il
http://support.hp.com/in-en/document/c05235419
Update : " Sorry it should be posted in the desktop Section, I didnt note it. SOrry agian since i am talking about my desktop pc"
What's your budget, and can you measure the inside of your case from the PCIe slot to the inside of the case opposite it, and from the back part of the PC where additions to to the closest point in line with the PCIe slot.
I need the depth of the case from sidewall to pcie slot and shortest length from back to front in line with the slot is what I mean.
Also can you post an image of the inside of the case similar to the way the first picture is.
Height: 31.95 cm (12.58 in)
Width: 39.60 cm (15.59 in)
Depth: 10.01 cm (3.94 in)
Weight 4.40 kg (9.70 lb) - without packaging
