Hello,
I've recently decided to buy a new display for my aging PC, And ordered Samsung T260 25.5" display to replace my old Samsung SyncMaster 931c. Since my old resolution was only 1280x1024 (compared to the new 1920 x 1200), And I allready had performance problems with many games, I began thinking about upgrading my PC.
My PC specs:
Motherboard: Intel DP965LTCK (775 conroe, Intel P965, DDRII 800, PCI-E, HD Audio, 1394, GBL)
CPU: Core 2 Duo E6300 1.86Ghz 2MB Cache S775 1066MHZ
GPU: PowerColor X1950 pro 256MB GDDR3 Arctic Cooling 2xDVI VIVO PCI-E Retail
RAM: 2 * TWINMOS DDR-II 667Mhz 1GB
Since I was upgrading the display I thought about buying a graphics card. After looking at the charts and comparing prices (And since I had problems with ATI drivers) the Zotac GeForce GTX 260 looked like the card I wanted to buy.
My questions are:
1) On the GTX 260 specs it says "PCI Express 2.0 x16 (Compatible with 1.1)". Im not sure, but I think my motherboard PCI-E version is 1.0. According to what I read the GPU can run on 1.0 as well. Is this true? Also, does that mean I will have reduced performance?
2) Would upgrading the GPU enhance performance enough to justify the cost? As you can see, My CPU is quite old, And it will be hard for me to find a new one because my motherboard is quite old as well, and cant support newer CPU's.
3) Is the GPU I chose fit for my comp, or should I choose some cheaper GPU because the GTX 260 is too good for my PC and not worth the price? For example use the money to buy a cheaper GPU and a PCU - If so, Can you please give me an advice about the CPU as well?
If you have other advice or suggestions to share I would be very interested in hearing them.
Thank you.
Btw, Im new on this forum, so Im sorry if I did something wrong.
My PC specs:
My questions are:
Thank you.
