Question [Need Help/Info] CoolerMaster ML360R RGB
Zaselim
123
Hello everyone,
I just got and installed the liquid cooler (on my i7 6700k) and also installed CoolerMaster Plus software and CM+ showing all the temps (CPU,GPU,Ram) but it is not showing the Cooler stats (Temp, fan/pump speed) and there is no option to set the profile for the cooler like balance, quite or performance. In the profile it only asks me to select the execute able (exe) file.
So did i miss something or is there any other app for it and that is why i am having this issue? Or is it only run in auto/company setting mode?
The cooler itself working fine because my CPU temp is in 29C (25-29) and its running very quite which is a good sign as well. But i want to setup my own custom speed and pump levels.
I'll be very grateful for the help, Thanks.
