wheato :
maxalge :
wheato :
i have a Zoostorm PC and I can't seem to install the graphics card I have. I am running an Intel(R) core(TM) i5 CPU and 8gb of RAMM. i believe there are onboard graphics running
http://www.techpowerup.com/gpuz/
Install gpuz, then post a picture of it running.
What do you mean by you can't install the graphics card? Explain exactly what you are trying to do.
I tried to install the graphics card before. Put it into the PCI port and there was no picture when I booted the PC up. Also what is the programme I need to download ?
Ok couple of steps:
Uninstall all graphics drivers.
Turn off pc. Make sure all proper power connectors are attached to the card and it is seated properly in the slot..
Hook up your monitor to your graphics card.
Turn pc on, go into BIOS. Disable built in graphics, set primary display to your discreet: PEG, or PCI express.
Reboot.
You should now boot into windows, install the drivers.
