R rtonasket Prominent Feb 6, 2018 4 0 510 Feb 6, 2018 #1 I'm having trouble getting power to my GPU. I have the corsair 850i psu but when I connect my two 6+2 pins and boot the pc I'm not getting anything out of the card. No fan spinning or display to my monitor. Any ideas?
Barty1884 Retired Moderator Apr 16, 2015 22,254 1,355 108,740 Feb 6, 2018 #2 Is the GPU known, working? Are you connected directly to a x16 slot, or attached to a riser etc? Please post your full system spec. Upvote 0 Downvote
R rtonasket Prominent Feb 6, 2018 4 0 510 Feb 6, 2018 #3 Barty1884 : Is the GPU known, working? Are you connected directly to a x16 slot, or attached to a riser etc? Please post your full system spec. Upvote 0 Downvote
R rtonasket Prominent Feb 6, 2018 4 0 510 Feb 6, 2018 #4 Barty1884 : Is the GPU known, working? Are you connected directly to a x16 slot, or attached to a riser etc? Please post your full system spec. Upvote 0 Downvote
R rtonasket Prominent Feb 6, 2018 4 0 510 Feb 6, 2018 #5 https://pcpartpicker.com/list/JzLJ7W Directly into the pcie slot with no riser Upvote 0 Downvote
