Need help installing rubber fan screws
Put them in through the outside of the case and through the first hole of the fan, not through both. Then grip and pull them through, you'll feel it settle in the groove. They don't hold them super-tight or anything, so don't be afraid of a tad bit of give.
Thanks for the replies. I guess I'm also wondering how would I put in the regular screws that came with it, if I wanted a more secure fit?
These screws are very short with wide threads, were they not designed to go in the front of the case?
