M mcdowjac Honorable Sep 11, 2013 1 0 10,510 Sep 11, 2013 #1 I want to put my 2.0 TB hard drive in my cyberpower PC but it won't recognize it when i plug it it. What am i missing?
Solution T T Themurkiest Sep 11, 2013 http://www.tomshardware.com/forum/295849-32-hard-drive-show-read Control Panel -> System and Security -> Administrative Tools -> Computer Management -> Storage -> Disk Management. Your harddrive should have two wires, one for power and one for the mobo.
T Themurkiest Honorable Mar 14, 2013 54 0 10,640 Sep 11, 2013 Solution #2 http://www.tomshardware.com/forum/295849-32-hard-drive-show-read Control Panel -> System and Security -> Administrative Tools -> Computer Management -> Storage -> Disk Management. Your harddrive should have two wires, one for power and one for the mobo. Upvote 0 Downvote Solution
kenrivers Illustrious Dec 29, 2010 6,684 6 37,015 Sep 11, 2013 #3 Check to see if the drive is recognized in the BIOS. If it is, then it is properly connected As was mentioned by Themurkiest you will need to go into Disk Management and initialize the drive. Upvote 0 Downvote
