C CTT2210 Jun 12, 2019 68 0 30 Jul 15, 2019 #1 So I bought this monitor: DELL S2417DG. It seems that the bottom edge has a curve towards the right speaker. Is it normal? https://imgur.com/a/1fqm0mw
D Deleted member 14196 Guest Jul 15, 2019 #2 I went here and looked at their photos but I can't tell from all the messy stuff on that pic I would call dell and send them photos, maybe they can be accurate help. Upvote 0 Downvote
C CTT2210 Jun 12, 2019 68 0 30 Jul 15, 2019 #3 Thank you for your answer. I think the refresh rate is fine. Upvote 0 Downvote
hang-the-9 Titan Mar 25, 2010 60,387 1,081 152,940 Jul 17, 2019 #4 Looks like a small plastic bend or it's not clicked in all the way into some clip, I would not worry about that. Upvote 0 Downvote
