need help just build my first pc
jbugz
i just build my first gaming pc everything seem to go smoothly.
spec
intel i5 4670k
msi z97 g45 mobo
corsair veng 8g memory
evga 970 gpu
corsair 750 power
samsung ssd
now the problem i'm having is i power the pc for the first time and it turn on, so when i got to reboot black screen i input the operating system cd window 8.1 evrything whent smooth did some simple steps and i agreed to the terms and then it when thru some install process up 100% then it said system need to restart ok so it did but ince it turn of it turn back on and its stuck on windows logo screen.
so i restart the pc about 3 time and same problem stuck on windows logo screen
now the second time i restarted i got and error msg . it was like 0cx0000001
any help would be great
it is usually happens due to
1.Driver problems/compatibility issues
2.HDD errors
3.OS problems
Try this,it may help you
Restart-->Press shift+f8 repeatedly-->click Advanced repair options-->click Troubleshoot-->click advanced potions--> click windows startup settings-->click restart
2.HDD errors
3.OS problems
