Need help! Keep getting bue screen on every monitor.
SpaceCreation
75
I recently just finished my build and as I try to plug in the vga slot into all of my monitors, the screen keep getting blue and showing this. http://imgur.com/2bqhaNk .
Motherboard: 78lmt-s2
CPU: AMD FX-4300
GPU: radeon HD 6670,
I plugged the vga into the gpu card, also I have the F6 bios update in my flash drive ready and Im planning to update the motherboard, But idk what the screen is saying and the keyboard is not working for some reason.
Thats definitely a hardware issue.
Didn't really understand your post that much, but try remove the gfx card and try another.
Next id be isolating the ram (mainly because its easy)
Then it's likely the mobo thats faulty.
