Need help knowing if this is even possible.. Egpu idea
zachfrazer27
As said above I need help knowing if this is even possible.
(i know an egpu is possible but this is a new idea)
1. get http:// witch would go into the MPCIe on laptop.
2. get http:// or something similar.
3. plug the riser into the laptop, plug the pcie into the riser
4. plug your graphics card in, and plug your wifi card back into riser (i know i would need a new wifi card)
of course your would need power for the graphics card..
just curious if this would work? im new to this side of computers so bare with me.. thanks!
It should work in theory but then you have antenna acabling you need to also worry about. Those are usually built intot he sides of the dispaly.
Why not just buy a USB wifi adapter anf guarantee it work.
