Need help looking for prebuilt
imperfecta
I'm looking to buy a prebuilt pc, it would be my first gaming pc.
I thought about building one but in all honesty, I just don't want to (next time I will). My budget is roughly 1200$, I'm looking for advice from.... I guess a seasoned pc gamer.
I don't care for VR and the games I will play will be primarily overwatch and paradox strategy games. Thank you in advance.
Honestly buying one is the only viable way of getting a mid to high end PC with the GPU market so messed up thanks to miners. Xidax has pretty good prices and although a newer company ive heard good things. The best way to see if you are getting a good deal is to try and price out a computer as you would build it yourself then see how much more the company is going to charge you, but if it includes a good warranty factor that in as well.
I chose these components though Avadirect's site. I used the first desktop on that page that starts at $639.
Source Series S340 w/ Window, No PSU, ATX, Black, Mid Tower Case
Z370 Pro4, Intel Z370 Chipset, LGA 1151, HDMI, ATX Motherboard
Core™ i3-8350K Quad-Core 4.0GHz, LGA 1151, 91W TDP, Processor
GeForce GTX 1060 GAMING ACX 2.0, 1506 - 1708MHz, 6GB GDDR5, Graphics Card
16GB Kit (2 x 8GB) HyperX Fury DDR4 2400MHz, CL15, Black, DIMM Memory
SSR-550FX, 80 PLUS Gold 550W, Fully Modular, ATX Power Supply
Freezer 33 Plus, 150mm Height, 160W TDP, Copper/Aluminum CPU Cooler
1TB Blue WD10EZEX, 7200 RPM, SATA 6Gb/s, 64MB cache, 3.5-Inch OEM HDD
Standard Wiring with Precision Cable Routing and Tie-Down
AVA Basic (2-Year Labor / 1-Year Parts)
It came to $1225 before taxes.
