So here are the components i have and i need to know if it will work correctly. So please look at the list : MOBO: GIGABYTE H81M-S2PV CPU: INTEL CELERON G1840 2xCORE 2,80GHz RAM: ZEPPELIN 4GB DDR3 1333MHz PSU: 500w approx
And of course i got some HDD and case.. And 500w cuz I will purchase some 2GB gaming GPU.
One last question.... Will ATX psu fit in mATX case?
1| Not all cases are built equally, some will be HTPC style while some are tower style. So the question is what is the make and model of your case? Can you provide a link to all the parts you've listed above?
2| The PSU looks like the worst part in your list since a bad quality PSU can and will damage more than just the system. It can take your house/life with it too.
3| Adding just about any GPU will nto be a fruitful situation since there are varying GPU architecture's. Depending on which GPU you choose you'll either be in good hands or suffer from a sever bottleneck from your CPU and I doubt you're looking at a GT530 GPU.
You might have better returns if you went through this thread and followed up your post with the necessary details to help us source a build within your budget that fits your requirements.
