Need help making an incandescent backlit monitor to alleviate headaches
mb23
I’m trying to change the backlight of a computer monitor to incandescent or halogen. Can I buy a 19” LCD or larger without the backlight, and install my own light source, and where could I purchase it from? If this is not possible is there a 19” or larger monitor that I could easily take apart and try this with. A friend of mine tried this with a Dell 19” monitor, but was unable to get the light to shine through the LCD.
The reason for changing the backlight is I have problems with computers screens giving me headaches within 10 to 15 minutes. All LCD monitors cause this problem including CCFL backlit, LED, and even the iphone. I bought a 23” EIZO EV2336W monitor that is IPS and has no PWM when the brightness is above 20. Unfortunately this did not work.
Based on everything I have tried, I believe that it is the light itself that causes the headaches, and I think it has to do with the uneven spectrum of the light that it produces. I recently purchased a laptop made by SunBook that has a transflective screen. As long as the backlight is off I can use the laptop all day without any problems. The disadvantages are that I need a good light source to read the screen, the screen is only 10 inches, and the screen is black and white. The solution that I believe will work is switching out the backlight with an incandescent or halogen light. I know the incandescent will work since I had the light shine through a laptop LCD and it didn’t give me a headache. I need a larger stand alone monitor at work, and that’s why I tried the 19” monitor.
If I’m unable to get a regular LCD to work then I’ll probably get the 22” transparent LCD sold by Orion, and shine a light through the display. I’m not sure how the quality would be since it is a transparent screen and it costs nearly $700. If anyone has any suggestions I would appreciate it.
Thanks,
Michael
I have actually done this once. I had a laptop with a blown inverter so I rigged a incandescent bulb behind it.
It worked very poorly (very dim) because the white reflector/defuser on the back.
The LCD displays have a thin tube for the CCFL so you cannot easily light it with something large.
It may not be the light giving you headaches but rather it may be focusing on it may be causing it.
Thanks for the responses, but I don't think those are causing the problem. I don't think the refresh rate is an issue because the transflective lcd doesn't bother me as long as the backlight is off. If it was the refresh rate the transflective screen should still bother me. Would the refresh rate be an issue on a regular lcd if nothing is moving, because a still screen will also give me a headache.
I've tried gunner glasses with the yellow tint but this did not help much. I even bought glasses that completely blocked blue light, but it only helped a little. Computer glasses help with focusing problems and glare. Since the transflective screen doesn't bother me I don't think this is the issue. I've also been to the optometrist, I have excellent vision, and the optometrist didn't have any suggestions for me.
I have tried many different solutions, and I think I've eliminated all the other possibilities. Especially since the transflective screen and incandescent backlit laptop I tested don't give me headaches, I'm pretty confident that the light is causing the problem.
