Ok so I just replaced my mobo, CPU, memory and am having issues. They system bombs out after not long gaming and won't last 1 minute during the OCCT test. My specs are below, but it works fine if I keep 1066MHZ on the memory but when i load the XMP profile or manually enter it, or enter 1.65V on the memory it bluescreens on me. I have RMA'ed the Motherboard already and everything is at default in the BIOS exept the RAM. Before I RMA'ed I borrowed 3 sticks of my Buddy's Dominator 1866 memory and tried that. With XMP on or manually entered it does the same thing. However at a lower speed it was fine. My only other thoughts are the CPU, since the memory controller is on that, could that be the cause? OR I did not reinstall Vista when I replaced the hardware. Should I reinstall? I never had an issue with doing this in the past once all the drivers we installed. It seems odd that at 1066 Vista is fine and no issues. Please Help.
Intel i7 920
ASUS P6T
G.Skill DDR3 1600 2GBx3 8-8-8-21 Pi Series
Intel i7 920
ASUS P6T
