Is my motherboard compatible with this gtx 780ti? maybe its the cpu as well. I had a gtx 580 in this system. Took it out installed gtx 780ti and everything worked fine. When you restart the system then monitor just stays dark. It will not turn on. After multiple restarts it turns on.
Once its on it stays on as soon as you restart it just takes forever to get on again. What do you guys think?
Intel Processor - i5-2500K 3.3GHz, 3.7GHz Turbo Boost
CPU Cooling - Corsair Hydro H80 Liquid Cooling
Intel Motherboard - ASUS P8Z68-V LX [VGA DVI HDMI] SATA 6Gb/s USB3 {4 DDR3 Slots}
Memory - 16GB (4x4GB) DDR3 1600MHz
Primary Hard Drive - 1TB 7200 RPM
Graphics Card - Nvidia Geforce GTX 580 3GB
Power Supply - Corsair Enthusiast Series TX750 750 Watt 80 Plus Bronze
