Hello, I'm building a system with 3 seperate loops, and therefore I need three pumps, I'm using EK D5 pumps which are rated at 23W 12V.
Link: https://www.pccasegear.com/products/33817/ek-xres-140-revo-d5-pwm-pump-reservoir-combo
Now here is where I'm confused, on the motherboard I'm planning on using it has six Sys Fan Headers in total and it states that all fan headers support high current 24W fans at 12V 2A, but then it also states that two of these six Sys Fan Headers have support for 24W water pumps.
This is the link for the motherboard: https://www.pccasegear.com/products/37823/gigabyte-aorus-z270x-gaming-9-motherboard
I guess what I'm asking is, can I use a regular Sys Fan Header for my third pump?
And on another note, what would the difference between a 24W fan and a 24W pump be? Wouldn't they have the same power draw?
Anyone help would be insanely appreciated. Thank you.
