First, apologies if this is a total noob question as I'm sure it is. I am currently working on my first major build, as well as my first foray into liquid cooling AIO's.
I've run into a bit of an issue in installing my Swiftech H140-X cooler into the my Thermaltake L10 GT. Preferably, I would like to mount the radiator from within the case at the top. However, the case is a bit wide, and even the screw holes for mounting fans at the top are too wide apart to really find a good spot to place the radiator. So, I can't really find a proper place to install it at the top.
The back of the case is fine however, in that if I wanted I can easily mount the radiator (albeit vertically). But, I really would like to have it placed from within the case onto the top panel.
So, does anyone have a suggestion, or a workaround for this? Or a mod suggestion? Sorry if this is a dumb question.
