need help moving steam and origin from ssd to hdd
Sep 19, 2018
33
Building a newish system using the same storage. I need to fresh install windows so that process will delete everything on my ssd. The problem is I have the main program files of steam and origin on my ssd and would like to transfer them to the hdd before I make the switch i just can't find them and i don't know how to transfer them.
If you're just trying to move the games over you will want to goto the file manager then "This PC", "Whatever your SSD is", "Program Files" or "Program Files x86", "Steam", "Steam Apps", "Common". The steam games should be right in there and Origin should have something very similar. It should be sitting next to the steam folder.
If this doesn't make much sense, you can try this link.
https://lifehacker.com/how-to-move-a-pc-game-to-another-hard-drive-without-re-1714706774
Moving Steam games is easy
Steam games location
In the steam client:
Steam
Settings
Downloads
Steam Library Folders
Add library folder
To move an already installed game
Games library
Right click the game
Properties
Local Files
Move Install Folder
I believe Origin has a similar function.
