Need Help My first Gaming PC?
12carzam
12
I am thinking about building my first PC, but my first choice was to buy a pre-built PC from cyberpowerpc, but after all the bad reviews i have herd about the company I have decided to try, and build my own. So I used cyberpower's website to configure a PC, and buy all the parts from Newegg. As i don't know much about building a PC I wanted to know if the parts I have chosen are compatible, and/or any good.
Here are the specs of the PC I would like to build:
Case-http://www.newegg.com/Product/Product.aspx?Item=N82E16811119305
Motherboard-http://www.newegg.com/Product/Product.aspx?Item=N82E16813131872
Graphics Cards-http://www.newegg.com/Product/Product.aspx?Item=N82E16814487088
Power Supply-http://www.newegg.com/Product/Product.aspx?Item=N82E16817438018
RAM-http://www.newegg.com/Product/Product.aspx?Item=N82E16820233299
CPU-http://www.newegg.com/Product/Product.aspx?Item=N82E16819113284
CPU Cooler-http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099 or http://www.newegg.com/Product/Product.aspx?Item=N82E16835103189
I will be using a 1 Terabyte Western Digital Hard Drive, and a 128gb Kingston SSD.
If you think i should change some parts i would appreciate anyone's opinion on the matter.
I have changed motherboards for this one here http://www.newegg.com/Product/Product.aspx?Item=N82E16813130790.
The only notes i get is that i may need to update the BIOS.
Is there much of difference between the i5 over the FX CPU?
Probably 40% faster or more.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($219.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($26.98 @ OutletPC)
Motherboard: Gigabyte GA-Z97X-GAMING 7 ATX LGA1150 Motherboard ($128.99 @ SuperBiiz)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-2400 Memory ($59.98 @ OutletPC)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($44.10 @ SuperBiiz)
Video Card: MSI GeForce GTX 970 4GB Video Card ($308.99 @ SuperBiiz)
Case: Cooler Master HAF 912 ATX Mid Tower Case ($47.70 @ SuperBiiz)
Power Supply: XFX TS 550W 80+ Bronze Certified ATX Power Supply ($71.98 @ Newegg)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($16.98 @ OutletPC)
Operating System: Microsoft Windows 8 (OEM) (64-bit) ($83.70 @ SuperBiiz)
Total: $1009.39
Generated by PCPartPicker 2015-05-25 17:01 EDT-0400
Is there any Motherboards you recommended.
