Pc specs:
Intel core i5 4670k
Gigabyte GA-Z87X-D3H
2x4gb Corsair Vengeance DDR3 1600
MSI R9 290 4G Gaming Edition
1TB HDD
850W PSU
I bought the cpu,ram,gpu and motherboard used from a guy and I was told that the mobo didn't work,so I bought a stock house cheap h81 motherboard and then I found out that a stick of ram was bricked and after only a few weeks the cheap motherboard started randomly freezing.I thought about testing the ''not working'' motherboard and maraculously the system worked fine until a few days later, the electricity went down in my house when the pc was turned on.After that,the pc would boot loop or the pc speaker would beep every 3 seconds or so,and after searching it online I took a ram stick out (yes,I replaced the bricked one) and the pc turned on.Just out of curiosity I placed the stick that I took and put it back in and the pc booted up! I thought I fixed the problem but ever since then every time I try to open the pc after I shut it off it will boot loop or the pc speaker will beep for 3 second or either the speaker will beep constantly.I have tried to use olny one stick of ram but the same thing keep happening.Plese helps me!!!!
Intel core i5 4670k
1TB HDD
850W PSU
