Need help - need a keyboard with REAL rollover (REAL anti-ghosting), please recommend me a keyboard
konopes
hey guys (and girls) I am looking for a keyboard (the cheaper the better) which would allow me to press 4 keys at the same time
I can´t press up, left and then space, it just does not take space
also I need it in combination with left CTRL
I already tried 2 gaming keyboards, they were supposed to be anti-ghosting, one of them with 10 key rollover, but still...
any tips? I don´t want to spend 80-200 euros for a mechanical keyboard unless absolutely necessary
If the keyboard with 10 key rollover did not work, I would think the problem is not with the keyboard.
Do you have a PS/2 port on your motherboard that you are using for they keyboard? Are you using a KVM switch or adapter? Most (all?) USB keyboards are not able to support rollover without a special driver.
