Need help...need pros and cons.
What are you going to use it for?
Intel CPUs are generally a little bit better than AMD's offerings, but the Turion II will be fine for most people. The HD 4200 is also an integrated graphics card, so if you are looking to do any gaming you may want to consider a dedicated solution.
Latest posts
