Question Need help! New build not working
Mar 21, 2019
9
So I’ve upgraded to the mai 390 edge ac mother board with a i7 9700k , rtx 2080ti 3200mhz of ram 16 gb, 500 gb m.2 evo
So I’ve made sure everything was wired to the right places on the board and doubled my tracks for no mistakes. As I when to go turn on the pc the ram rgb it lit up all fans are running but the rtx instantly ramps up to full speed for a second and then goes back down to maybe 60-80 percent on one fan witch is very odd with no led on the card. I can’t even get into the boot screan it’s just black . I need some help! I think it might be the moba is fried or the processor is messed up. The gpu is fine because I put it in my old system and it’s working fine there just not in the new build
Dec 29, 2018
8
I had an issue with a bad powersupply where they fans on my gpu would go max speed and not display anything. What brand psu are you using?
