[SOLVED] NEED HELP - Newly built AMD pc NOT working properly
dreamer9t9
62
Hello Friends,
I have build a new PC for Gaming Work need but its not working properly. Below are all the details point wise:
HARDWARE:
motherboard: MSI X370 Gaming Plus
processor/cpu: AMD Ryzen 5 1600
ram: Kingston 8gb (ddr-IV 2400 MHz)
graphic card: Nvidia 1050ti
cabinet/smps: Cooler Master CMP 500 with 400watt SMPS
OS: Windows 10
Software I have to use:
Autodesk Maya
Zbrush
Photoshop
Topogun
etc
Problem:
while working in maya (mostly) and other soft, sometimes - lags, freez and bluescreen.
even sometimes it gives bluescreen, right after starting the PC.
Its the newly built PC and still i couldn't use it properly due to these issues.
Please advise.
Thanks in advance for all the help.
- Raj
Its mostly likely a power issue or a heat issue.
Power is difficult to diagnose however temps are easy so check them first, as well as doing what you mentioned above.
Do you have the 8 PIN Power lead plugged into the socket above the CPU? People often forget this and it can cause the CPU to be starved of power at load.
how are the cPU temps at full load?
if they are up around 80c you could have a problem with the cooler not seated right, causing the system to over heat at load.
Another thing i would suggest you try is reseating the RAM to makes sure its in correctly.
Will try to check the CPU thing. and adjust the cooler as well.
and i already tried reseting RAM multiple times. NO HELP.
Anything else i can do?
