G
Guest
Guest
Archived from groups: alt.comp.hardware.overclocking.amd (More info?)
Hi there!
I've asked this question already in
alt.comp.periphs.mainboard.msi-microstar.
A friendly guy named Chris told me to ask again here, he wrote:
"There is a guy there named Wes Newell that has extensive knowledge of
doing exactly what you want to do, and he may be able to help you out."
🙂 So, I'll ask again....
At the moment I'm trying to run a MSI K7TM Pro (MS-6340 Rev V3) with a
frontsidebus of 133Mhz. (I want to use a 1800+ Palomino) Specs and CPU-Table
for that board say that it's possible. Unfortunately is only runnin' at FSB
100.
As soon as I short circuit jumper J9 (as mentioned in the manual at 2-30)
the
board doesn't boot. No POST, no video, nothing - only the power supply
and the (cpu-) fans are runnin'.
What I've done to fix this problem (without success):
- updated the bios to the newest version V4.7 (W6340VMS.470)
- cleared cmos / resetted bios to default / failsafe settings
- tried different 3.3v SDRAM DIMMs (Kingston, Infinion)
- tried another AMD Athlon XP 1800+ (Palomino)
- tried another power supply (350 W should be ok...)
- clicked through different FAQa
- getting lotta grey hairs
The board runs fine & stable at FSB 100 (10x11.5?) with WinXP Pro SP1.
Does anyone of you have a brilliant idea to run that board with a FSB of
133?
Actually, it should be able to...
Kind regards & full of hope,
Stefan
Hi there!
100.
the
133?
Stefan
