Solution RealBeast Aug 8, 2020 AtlasNomad said: AMD Ryzen 7 2700 or INTEL I5-8500T Click to expand... The Intel is a little faster as you can see HERE. Can you consider other CPUs, like the third generation Ryzen CPUs? What's your budget?
RealBeast Titan Moderator Sep 13, 2010 17,109 473 104,790 Aug 8, 2020 Solution #2 AtlasNomad said: AMD Ryzen 7 2700 or INTEL I5-8500T Click to expand... The Intel is a little faster as you can see HERE. Can you consider other CPUs, like the third generation Ryzen CPUs? What's your budget? Upvote 0 Downvote Solution
