Hello,
I picked up the new NZXT kraken x52 and I have had it for a few days now and I noticed, while doing some cable management, that the plastic backplate that the block attaches to is warping inwards towards the motherboard.
Album here: http://imgur.com/a/GXvMh
It looks dangerous to me, and the plastic is getting really close to those silver things on the rightside and possibly touching the mobo on the leftmost side .
The strange part, is that it is functioning fine. On a cold start up it rests between 17-19C and after a few hours bumps up to 20-23C. I have stress tested this for more then 4 hours on prime95 a few times and it hovers at 40C once the fans kick in (peaked at 60C for a sec) . Additionally I haven't run into any issues, the only thing is that my Kraken stock fans like to buzz (update: not the fans, the actual pump/block is clicking/ rattling )
(sidenote: they aren't even labeled with directional arrows, and yes I have them in the right way) 🙁
My build incase that's necessary:
- i7 6700k
- Gigabyte gaming 7 Mobo
- EVGA FTW 1070
- EVGA supernova 650 watt PSU
- Phanteks enthoo evolv tg
- samgsung evo ssd
I am curious if this is normal or something for me to worry about. This is my first build and so I am a little nervous messing around with it. I am pretty sure I didn't wrench the screws too hard, as I only tightened till I felt a little bit tension and the board itself does not look to be warping. I am glad that it is functioning beautifully, but I am worried that this might be a problem in the future.
Any help would be very appreciated , thanks <3
Edit: Also, is this fixable? Do I have to order a new plate from NZXT?
- i7 6700k
- EVGA FTW 1070
- samgsung evo ssd
