Hello Hello.
I've had my 3800+ for quite a while now and I think it's time to overclock. But i just can't get it to boot past 2.05GHz. Sad.
I did a search in this forum and found some very helpful threads on overclocking the 3800+, but I think the settings in my BIOS are strange.
Hopefully someone can help!
CPU:
AMD Athlon 64 X2 3800+ Manchester socket 939
ADA3800DAA5BV
CDBHE 0531TPAW
Stepping E4
MOBO:
MSI K8N Diamond Plus
bios version: 1.0 ? date 12/14/05
Mem:
2x 1GB OCZ DDR400 Platinum
stock timings: 2-3-2-5
Now, i took advice from another thread which says to set the CPU:MEM ratio to 5:4. Well this is where my motherboard confuses me. It shows DRAM/FSB options of { 1/2, 2/3, 5/6, 1/1 }.
Here's a list of the overclock options in BIOS...
CPU
FSB: 200 - 450 MHz
Multi: x5 to x20
Volt: 1.4v - .8v
extra cpu voltage: +/- .05 or something
MEM
Auto/Manual
Memclock: DRAM/FSB: 1/2, 2/3, 5/6, 1/1
DDR volt: 2.6v - 3.2v
Mem MCT timings: (CL, TRC, etc.....)
PCIe freq (100 - 148 MHz) (no option to 'lock' it)
PCIe V: 1.5v - 1.85v
HT C51D config: (configures the speeds between the CPU, the NB and the SB)
Spread Spectrum: SATA and PCIe: Enabled/Disabled
Spread Spectrum: CPU and HT: Disabled, Center, Down Spread
These are all the options available in the Core Adjustments section.
Hopefully someone can help with some setting to start with and hopefully move up to 2.4 or more.
CPU:
ADA3800DAA5BV
CDBHE 0531TPAW
Stepping E4
MOBO:
Mem:
CPU
FSB: 200 - 450 MHz
Multi: x5 to x20
Volt: 1.4v - .8v
MEM
Auto/Manual
