Need help on 1300 gaming pc before I order.
IrieY56
This will be the first time I'm going to build my own computer so I need help to make sure the parts work with each other and reccomendation on other parts. My hard drive died and my computer is already quite old (5-6 years) so I decided it was a good time to just get a entirely new one. I took 2 reccommended builds and put them together for a start.
Approximate Purchase Date: Today
Budget Range: 1300$ after rebates
System Usage from Most to Least Important: Mostly gaming, some web surfing.
Parts Not Required: Keyboard, mouse, moniter, speakers.
Preferred Website(s) for Parts: Newegg.com
Country of Origin: USA
Parts Preferences: None.
Overclocking: Yes.
SLI or Crossfire: Probably later.
Monitor Resolution: 1680 x 1050 or 1900 x 1080 when I have the money for a new moniter.
Additional Comments: Perfer a quiet pc.
Seagate Barracuda ST31000524AS 1TB 7200 RPM 32MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148697
ICY DOCK MB882SP-1S-1B 2.5" to 3.5" SSD & SATA Hard Drive Converter - Black
http://www.newegg.com/Product/Product.aspx?Item=N82E16817994064
HIS H695FN2G2M Radeon HD 6950 2GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161368
CORSAIR Enthusiast Series TX750 V2 750W ATX12V v2.31/ EPS12V v2.92 80 PLUS BRONZE Certified Active PFC High Performance Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139021
Arctic Silver 5 Thermal Compound - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16835100007
G.SKILL Sniper Low Voltage Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBSR2
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231461
GIGABYTE GA-Z68A-D3H-B3 LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128502
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) 4 x 256KB L2 Cache 6MB L3 Cache LGA 1155 95W Quad-Core Desktop Processor BX80623I52500K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
COOLER MASTER Hyper N 520 RR-920-N520-GP 92mm Sleeve CPU Cooler Intel Core i7 compatible
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103057
Windows 7 Professional Upgrade
http://www.microsoftstore.com/store/msstore/pd/productID.216644200
I need a 120-128GB SSD reccomendation.
For the windows 7 upgrade do I have to install windows xp then buy the upgrade or can I just buy it on another computer and use the back up cd instead?
Will 750w be enough when I add another 6950?
vigilante212
357
Your missing a tower. Consider the hyper 212+ cooler over the Hyper N its cheaper and works great. As for SSD anything but the OCZ vert II. Also Arctic silver was great 5 years ago, but better stuff is out now look at the IC Diamond compound. Also Make sure to check the manufacturers website to see if your memory is compatible with their MB.
Also if you have a valid copy of any previous Windows not OEM you can install 7 upgrade legitimately Go here to find out how. http://www.winsupersite.com/article/win7/clean-install-windows-7-with-upgrade-media
