Need help on a first build for a gaming rig
quietcavalcade
5
This will be my first fresh build (in the past I have upgraded GPUs and stuff but never a whole system). I am interested in building a new gaming rig. Because of financial reasons I want to do this in two steps. The first step is to upgrade the GPU and PSU now then upgrade the CPU and Mobo in about six months. Also, I hate hate hate my current case and am planning on getting a new one now as well. I've been reading the forums and came up with the stuff below. Any advice would be greatly appreciated
Approximate Purchase Date: the next 1-2 weeks
Budget Range: $400
System Usage from Most to Least Important: Gaming. I typically don't run graphics heavy games. That being said I would like to run Diablo 3 on medium to high settings. I would also like to be able to run the Witcher and Guild Wars 2 on medium to high settings.
Parts Not Required:
I plan to keep my motherboard and CPU for now and upgrade them in six months.
Motherboard - Intel DG965OT
CPU - Intel Core 2 Duo CPU 6320 @ 1.86GHz
Monitors
Keyboard
Mouse
HD
RAM
Preferred Website(s) for Parts: newegg or Amazon
Country: USA
Parts Preferences: None
Overclocking: Potentially. I was looking at the i5 2500k CPU for possible overclocking down the road. However, since I won't be purchasing for half a year I imagine the CPU options will be very different
SLI or Crossfire: No
Monitor Resolution: I use dual 23inch widescreen monitors.
Additional Comments: I would like to have USB 3.0 compatibility in the future
Parts I am considering:
Case - Antec Three Hundred Two
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129180
vs
COOLER MASTER HAF 912 RC-912-KKN1
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=4176827&SID=ns2dzhy7b0wd
GPU - I was looking at the Radeon HD 7850
http://www.amazon.com/Sapphire-Radeon-PCI-Express-Graphics-11200-01-20G/dp/B007JCNOZA/ref=sr_1_1?ie=UTF8&qid=1335034070&sr=8-1
vs the GeForce 560Ti
http://www.amazon.com/gp/product/B004L01QVM/ref=ox_sc_act_title_6?ie=UTF8&m=ATVPDKIKX0DER
PSU - ???. I was reading about different options and frankly, was overwhelmed by options. Any suggestions would be helpful.
Thanks.
Oh, in that case... Lian Li are usually pretty minimalist. To tell the truth, I don't know of that many completely minimal cases, but I tried to find some.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112318
11-112-318-TS
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146072
http://www.newegg.com/Product/Product.aspx?item=N82E16811112239
11-112-239-TS
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112304
11-112-304-TS
ddan49
1,549
You are NOT going to fit a 7850 into a $400 build. That being said, the 7850 is better ;)
I don't really understand how you're approaching this, either. So you're going to buy the parts separately, at different times? I wouldn't recommend that... compatibility issues start to arise. Also, if you buy the GPU before the CPU, you don't have a computer... you have a bunch of parts. So is your entire build supposed to be $400?
quietcavalcade
5
The $400 is for the case, GPU and PSU. I was planning on getting all those now and re-using the mobo/CPU/RAM. Then, in about six months, I am planning on purchasing a new mobo/CPU/RAM set.
ddan49
1,549
Okay, that should be fine. So... I'd really try for the 7850. In that case, here's what I would do. (oh, and what do you prefer in a case? I've got a sexy one, a quiet one, and an overall good one, in that order):
Case: NZXT Phantom... five color schemes I know of. Great cooling (200mm fans), really nice looking, expensive. Pics:
Fractal R3: Not superior cooling, but it keeps quiet. Minimalist design. Pics:
scaled.php
Corsair 400R: Nice cable management, cooling, and reliable company. A favorite. Pics:
Alternatively, you could get a HAF 912 for less... although I'd recommend a Corsair 400R as a basic case. The others are either for aesthetics or quietness. I'm going to assume the Corsair 400R since it's the cheapest:
Case: Corsair 400R - $100
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0CFQQFjAC&url=http%3A%2F%2Fwww.newegg.com%2FProduct%2FProduct.aspx%3FItem%3DN82E16811139008&ei=gjWTT-HRLufl6QH7x5S-BA&usg=AFQjCNGuMiEiJbnDOkrJ8jTjD9TXJ9XuyA&sig2=j-T-iB6YLMCoQgbHAgTsIg
GPU: MSI Twin Frozr II OC 7850 - $250ish... there's a problem here. It's been sold out at newegg for a while. If it's still sold out when you buy, get a Gigabyte version. MSI Twin Frozr II OC is much better, though...
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127663
PSU: PC Power and Cooling Silencer MK II 750W Silver Rated - $80 (with rebate)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817703027
Total: $430
Because of this, you may want to switch the case to either a HAF 912 or an Antec Three Hundred Illusion... it's up to you.
quietcavalcade
5
Awesome. Thank you so much. I will probably go with the HAF case but I really like those Fractal cases so might save up a bit and get that instead.
I appreciate all the help. Thanks again.
quietcavalcade
5
The aesthetics. I don't need to worry too much about quietness.
ddan49
1,549
11-112-318-TS
11-112-239-TS
11-112-304-TS
http://www.newegg.com/Product/Product.aspx?Item=N82E16811553003
11-553-003-TS
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112154
NZXT Gamma is a possibility.
Antec P280 is another "silent" case.
Overall, most minimalist cases are either crazy expensive or built for silence. It may be a good idea to go for the Fractal, after all...
