need help on best comp fan and setup for air flow
There is no such thing as a good $5 PC fan, but I admit that Rosewill fan doesn't look bad. For $5 you can't do better. Buy those and do the classic arrangement:
2 intakes in the front
1 intake on the bottom
1 exhaust on the back
2 exhaust on top
But you probably do not need that kind of airflow, so feel free to just do:
1 exhaust in back
2 intake in front
This will keep the air pressure just a bit higher than normal, helping to keep dust out.
i was gonna buy 3 fans and try to do 1 back/1top/2front/1 bottom(think bottom is worth it? isnt that gonna suck up dus?)
or should i just buy 2 and do 2 front/1back/1top?
dont need any fans on the side?
yeah i had my defaults 1 top 1 back in and my other 2 broke....comp running hot, had to grab a 80mm old fan out of my closet and put it blowin air in on the side....should help a ton until i order my fans tonight
