I wanted to build a cheap gaming PC so I originally planned to buy a refurbished office computer, and then put it in a new case with a gpu. I was able to get a gtx 960 2gb from a friend. I also got a Ranger R4 R for the case. This is the specification of the PC that I bought (https://www.cnet.com/products/dell-optiplex-9010-core-i5-3550-3-3-ghz-monitor-none-series/specs/). I hope that links are okay here. I then realized the PSU wasn't going to be enough so I got a Evga 600B.
After I started putting those parts into the new case, I ran into many issues. The motherboard only partially fits in (it fits but only a fraction of the screws line up). The majority of the front panel cable do not fit into the motherboard. I would have no USB 3 ports and none of the front buttons would work.
I know no way to make the cables work. I think that I will just need to buy a new cpu, motherboard, and cpu cooler. Which would you recommend to go with my RAM and GPU? I would like some sort of room for improvement. Will my RAM have some odd compatibility issues like the motherboard and cpu of the original unit? Ideally, if I need to buy those 3 parts, the total would be under $300. Thank you for any help and apologies if I've broken any community rules.
