Need help on building first PC
Torgontri
30
Hey everyone, I'm kinda new in building PCs and messing with hardware so I need a bit of help.
I have 2 old PCs and since I only use 1 I want to "mix" their parts and get some upgrades. The one I want to use is a HP a6000 http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01035996&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=3435609#N447
I want to use the i5 650 processor I have in the other PC since it's alright, but for that I have to get a new motherboard. I also want to buy a new GPU, the Sapphire DUAL-X r9 270x so I will need a new psu also. I'm kinda confused with all the many models and compatibility issues so I would appreciate if you could help me decide which motherboard and power supply to buy (preferably cheap ones, kind of in a budget here). Also, will all that fit properly in that HP case?
Thanks alot!
TL;DR Best cheap motherboard and psu for a HP a6000 case to support i5 650 processor and Sapphire DUAL-X R9 270x GPU?
Torgontri
30
Because in this one I can't use my i5 650 processor :/
Torgontri
30
So you think I should get a new CPU?
Torgontri
30
Yeah the other one works fine. The problem is that it's a mini ITX and I think I can't fit the GPU and psu in there. Or I have to buy specific hardware for it that might be more expensive
Torgontri
30
Hmm well I would say around 600-700E at most. I would use it mostly for some gaming and photo/video editing softwares. The thing is, those PCs are so old I'm not sure if I could sell any of those parts. Both GPUs are pretty bad, I think the only thing worth something might be the i5.
Thanks a lot for your help by the way! All this stuff is a bit confusing for me
OK, navigating amazon.es:
http://www.amazon.es/Intel-1150-i5-4460-Procesador-3-2/dp/B00K5J2306/ref=sr_1_2?ie=UTF8&qid=1422214149&sr=8-2&keywords=core+i5
http://www.amazon.es/ASUS-H97M-E-Placa-Socket-microATX/dp/B00K80MYNS/ref=sr_1_2?ie=UTF8&qid=1422214317&sr=8-2&keywords=h97
http://www.amazon.es/Seasonic-S12G-Fuente-alimentaci%C3%B3n-Superior/dp/B00FW6EICS/ref=sr_1_2?ie=UTF8&qid=1422214409&sr=8-2&keywords=seasonic+550
Up to about 360-370 euro there. What other parts do you need? HDD? DDR3 RAM?
Raiin
573
if your not video editing or using application that benefit from 6+ cores a i7 woudnt be wise,
the i5 4460 is enough for gaming, and i take it you wont overclock, so its perfect for you.
these are better boards
http://www.amazon.es/ASRock-H97M-PRO4-Micro-ATX-Crossfire/dp/B00KAY66NG/ref=sr_1_3?ie=UTF8&qid=1422215589&sr=8-3&keywords=h97+asrock
http://www.amazon.es/ASRock-H97-Anniversary-Socket-DDR3-SDRAM/dp/B00N9399TS/ref=sr_1_8?ie=UTF8&qid=1422215589&sr=8-8&keywords=h97+asrock
Torgontri
30
Hmm pero para eso habria que comprarlo todo para que lo monten entero no? Según dicen podré utilizar algo del PC viejo, y ya tengo algun amigo que sabe que me lo montara con suerte
Torgontri
30
Cool, thanks alot! So since the other stuff in my HP is really old, it won't have any incompatibility or bottlenecking with all the new components?
Torgontri
30
Alright then, the i5 it is. Thank you!
